The only IP address range that will work for the Ethernet over USB connection is 172.22.11.x. Changing the IP makes the ELVIS unusable over USB . Basically, Measurements Live and the ELVIS III board expect the IP address to be 172.22.11.2, so they are unable to communicate if you change it to anything else. There is also no way to configure the DHCP server to use a different IP range.
The only options are:
- Use Ethernet instead. This will allow them to use whatever IP address they want.
- Ask the IT department to allow the 172.22.11.x IP addresses.
