What Do the Different Property and Invoke Node Colors Mean?
Updated Sep 9, 2026
I am using LabVIEW. I have noticed that some property nodes have different colors. What do the different colors mean?
The standard color of a property and invoke node is yellow; however there are a few other colors that indicate differences that you should be aware of:
Color Codes for Property Nodes
ColorExampleNode TypeDescription
YellowStandardChanges a property of a given class.
RedDeprecatedThe functionality of this property has been improved in another function but has been kept in to support previous versions of code.
BlueVI ScriptingThe property is used in VI Scripting, for more information see the related links section.
BrownInternal/PrivateInternal or specific property which should be used with caution. The majority of these remaining will be changed to the other color types with future updates.
