Generating a Report for Run Selected Steps and Loop on Selected Steps
Updated Aug 14, 2019
  • TestStand
I have an all sequence from which I want select just some steps and generate a report from the latter. How do I generate a report for the Run Selected Steps?
  1. Go to Configure>>Station Options>>Execution
  2. Be sure that the checkbox Record Results is checked
  3. Select the steps that you need
  4. Right Click and select Run Selected Steps with Single Pass
