This error occurs when the measurement is not in range of what is expected for the bridge configuration, in order to ensure the task works efficiently make sure you check:
- You have the correct wiring for your bridge setup. You can consult the Connecting Strain Gauges and Shunt Resistors to the NI-9237 document if unsure of how it should be wired.
- Verify the cables are in a good state and working.
- Try in a different channel to verify if the module is working correctly.
- Contact your manufacturer to confirm the appropriate values are configured in the task.
Note: The NI 9237 is a full or half bridge completion module. If using a quarter bridge based sensor, then you will need to externally create a half bridge or use the NI 9944 or NI 9945 Quarter Bridge Completion Accessory. See the NI 9237 Operating Instructions and Specifications in the Related Links section for additional information.
