To modify the temporary directory path you can add the line
tmpdir=C:\folderpath to the Application.ini where
C:\folderpath can be any path on the target computer. The *
.ini file is automatically created by the LabVIEW Application Builder located in the same folder as the executable and named as your application. You can open it with any standard text editor.
Please make sure the directory you specify is valid and does exist. Otherwise the standard temporary directory of your operating system located under the user folders will be used.
Be aware that the *
.ini file will be overwritten each time you rebuild your application.
