Method 1: Download and Use the Offline Installer
Standard online reinstallations or repairs via NI Package Manager (NIPM) can fail to re-download or extract the large MSComp_S.prd database file (approx. 230 MB–1 GB).
- Completely uninstall NI Circuit Design Suite (or Multisim / Ultiboard) via NI Package Manager or Windows Control Panel.
- Download the full Offline Installer (.iso file) for your exact version of Multisim from the official NI Downloads page.
- Right-click the downloaded
.iso file and select Mount. - Run
setup.exe as an Administrator to perform a clean, complete installation. The offline installer contains all offline database payload files including MSComp_S.prd.
Method 2: Verify and Select the Database Path in Multisim
If the file exists on your system but Multisim lost its file path reference:
- Launch Multisim. When prompted with the message:
"Do you want to select the path where the component database can be found?", click Yes. - In Windows File Explorer, navigate to the default database directory:
C:\ProgramData\National Instruments\Circuit Design Suite\<version>\database\ (Note: C:\ProgramData is a hidden folder in Windows. Enable View » Show » Hidden items in Windows Explorer or paste the path directly into the address bar). - Select
MSComp_S.prd (or Master_Database.mcdb) and click Open.
Method 3: Manually Clean Up Residual Installer Folders Before Reinstalling
If reinstalling keeps resulting in the same missing file error, residual corrupted folders are preventing NIPM from overwriting the database directory:
- Uninstall NI Circuit Design Suite.
- Manually delete the leftover database folder:
C:\ProgramData\National Instruments\Circuit Design Suite\<version>\database\ - Manually delete the user settings folder:
C:\Users\<username>\AppData\Roaming\National Instruments\Circuit Design Suite\<version>\ - Reinstall Multisim using the Offline Installer.
Method 4: Copy from Another PC (If Available)
If you have access to a second computer running the exact same version of Multisim:
- Copy the
MSComp_S.prd file from:
C:\ProgramData\National Instruments\Circuit Design Suite\<version>\database\ - Paste the file into the same directory on the target computer.
- Relaunch Multisim.
