Can TestStand Communicate With a Docker Container?
Updated Jul 9, 2019
  • TestStand
I have a service that is running into a Docker container, and I need to interact with it from TestStand. Is it possible?
Yes you can communicate with your Docker container with TestStand. As Docker is available from the Command Prompt, and TestStand can make calls to executable , you can call the Command Prompt to control Docker.
