How Do I Generate Signal with FSK Modulation Message Using LabVIEW?
Updated Dec 22, 2022
  • NI-RFSG
I need to generate messages that I will send with a FSK modulation.
I don't know how can I do that in LabVIEW?
In order to use a modulation in LabVIEW:
  1. Install the LabVIEW modulation toolkit,
  2. See the example "MT RFSG Generate FSK"
This example show you how to continuously generate a message with a FSK modulation.
The modulation toolkit installs several examples to demonstrate how to perform modulation in LabVIEW.
