Measure Temperature in a High Temperature and High Humidity Environment
Updated May 3, 2018
  • TC-4353
  • PXIe-4353
  • SH96-96-1
I need to monitor thermocouples inside a chamber that goes up to 65 degrees C and 100% humidity. I have been looking at the PXIe-4353 with TC-4353 and SH96-96-1.
Can the TC-4353 be used in a 100% humidity environment?
Operating temperature range for both TC-4353 and SH96-96-1 is 0 to 55 degrees C and the humidity operating range is 10-90% humidity, noncondensing. See the TC-4353 installation guide for more information on the specifications.
For a more rugged solution, check out the FieldDAQ.
