Setting the Active LED on PXI-665x Module to Amber
Updated May 3, 2018
  • PXI-6652
  • PXI-6651
  • PXI-6653
The PXI-665x User Manual states that a user can set the color of the Active LED to amber. How do I do this?
To change the color of the Active LED to amber, the user can place an niSync Property Node onto the block diagram. Select the property "User LED State" and write a true constant to that property. This will set the Active LED as amber.
