Security Best Practices for LabVIEW VI Files
Updated Dec 22, 2017
  • LabVIEW Base
What best practices can I follow to protect myself from potentially malicious VI files?
A virtual instrument (VI) file is similar to any executable file such as EXE and DLL. You should exercise the same precautions with a VI file as you would with a EXE or DLL file.
The following guidelines help protect you from security issues related to VI files:
  • Only run VI files that come from a trusted source.  VI files downloaded from the Internet or received by e-mail should not be trusted.
  • Only run VI files from a safe location such as a protected Windows directory or a directory where you control the access permissions.
If you want to safely inspect a suspect VI before running it, follow these steps:
  1. Create a blank project
  2. Add the suspect VI to the project as a sub-VI
  3. Inspect the sub-VI's code
