There is no direct way to acquire directly through the FPGA on sbRIOs and cRIOs, because currently the only camera protocol that can be acquired through the FPGA is Camera Link. However, the sbRIO and cRIO can only acquire from USB 3.0 Vision (and most
USB webcams if Linux-based sbRIO/cRIO) and some of them (multicore cRIOs and Intel-based sbRIOs) GigE Vision cameras.
If you must acquire through the FPGA, you might be able to use a
Controller for FlexRIO along with the
Camera Link Adapter Module for FlexRIO . The other Camera Link frame grabbers are in PCIe or PXIe form-factor, which may be more difficult to integrate into an sbRIO system.
