Generating Pulse Train in SignalExpress
Updated May 11, 2018
  • NI-9481
  • SignalExpress
I am trying to generate multiple continuous digital outputs using SignalExpress to control NI-9481 relay module
Instead of using the "Create Digital Signal" option, you should use the Generate Signal option when creating a step. So just do Generate Signal»DAQmx Generate»Counter Output»Pulse Output. Then in the Step Setup window that pops up, set the Generation Mode to Continuous and configure the high time and low time as you desire.
