We found several reasons why this error may occur. Here are some troubleshooting steps.
- Make sure you have connected an external clock signal that is within the supported specifications.
- Make sure that the NI RIO Server is running by searching in Windows search for "Services" and setting the Startup Type as Automatic.
- If using FlexRIO, Make sure the component-level Intellectual property (CLIP) chosen for the FlexRIO Adapter Module (FAM) is in the latest version. See instructions here.
- Check if you are able to run any built-in examples related to your Hardware.
If any of the previous steps work, it is possible that some bad installation or corrupted software is causing the issue. After uninstalling and reinstalling all the needed software, modules, and drivers, the error was gone.
The problem may be resolved by simply force reinstalling just LabVIEW FPGA module.
