One way to measure velocity and position from one counter is to set up a counter task to take buffered position measurements. If you plot these position measurements against time, you can use the slope as the Revolutions Per Minute (RPM). Use the Unwrap VI in order to accommodate jumps from 360 to 0. Use the snippet below as a start:
