National Instruments does not actively maintain this document.
The USB-9211, USB-9215, and USB-9161 cannot be used with NI-DAQmx driver. These devices are only compatible with the driver, NI-DAQmx Base 2.2 and earlier, as referenced in the USB-9211 Series User Guide and Specifications and USB-9215 Series User Guide and Specifications.Note: NI-DAQmx Base is compatible with macOS 10.14 and earlier versions and starting 2018, NI-DAQmx for Linux is included with the NI Linux Device Drivers. Please check compatibility for Windows , Linux, and macOS for supported versions of this driver. For more information, please read the End-of-Life Announcement for DAQmx Base Driver .
A valid service agreement may be required, and support options vary by country.
