The USB-9211, USB-9215, and USB-9161 cannot be used with NI-DAQmx driver. These devices are only compatible with the driver, NI-DAQmx Base 2.2 and earlier, as referenced in the USB-9211 Series User Guide and Specifications and USB-9215 Series User Guide and Specifications.Note: NI-DAQmx Base is compatible with macOS 10.14 and earlier versions and starting 2018, NI-DAQmx for Linux is included with the NI Linux Device Drivers. Please check compatibility for Windows, Linux, and macOS for supported versions of this driver. For more information, please read the End-of-Life Announcement for DAQmx Base Driver .
