Install TestStand Sequence File Viewer
- Download TestStand Sequence File Viewer on the machine without TestStand installed.
- Unzip the zip file.
- Launch the setup.exe installer and follow the prompts to install the application.
Save the Sequence File as XML File
To view the sequence file in Sequence File Viewer, it must be saved in TestStand 4.0, 4.1, 4.2, 2010, 2010SP1, 2012, 2012SP1, 2013, or 2014 XML format. Follow the steps below on a machine with TestStand installed.
- In the TestStand Sequence Editor, navigate to Edit >> Sequence File Properties…
- In the General tab, select XML (most readable, largest) from the File Format drop-down list.
- Click OK.
- Navigate to File >> Save As.
- Select TestStand 2014 from the Files of Type: drop-down list. TestStand 4.0, 4.1, 4.2, 2010, 2010SP1, 2012, 2012SP1, or 2013 are also valid options you can select.
- Click Save.
View XML File in Sequence File Viewer
- Launch the Sequence File Viewer application from the Start Menu.
- Click on Browse…
- Select the sequence file you previously saved.
- The Sequence File Viewer loads the file for viewing.
Set XML as Default File Format
You also may want to set XML as the default file format for new sequence files.
- In the TestStand Sequence Editor, navigate to Configure >> Station Options…
- In the File tab, click the File Format Options... button.
- Select XML (most readable, largest) from the File Format For New Files drop-down list.
- Click OK.
