Using LabVIEW with PostGRESQL and Database Connectivity Toolkit
Updated Dec 12, 2017
Does the Database Connectivity Toolkit can an interface to PostGRESQL?
Yes. You can follow Tutorial: PostgreSQL with LabVIEW and use the LabVIEW Database Connectivity Toolkit User Manual as a starting point for creating your application.
The LabVIEW Database Connectivity Toolkit is a set of easy-to-use tools for quickly connecting to local and remote databases and implementing many common database operations without having to perform structured query language (SQL) programming.
