How Do I Migrate My PXI Cards to a New Chassis?
Updated Dec 20, 2017
  • PXIe-1075
  • PXI-1042Q
  • PXI-6224
  • PXI-5421
  • PXI-7330
  • PXI-6704
  • PXI-6733
  • PXI-6221
I'm working on moving all of my existing PXI cards from a PXI chassis to a new PXIe chassis and I'm want to make sure that my system will operate as expected.
When performing a major hardware or software migration, please keep the following steps in mind:
  1. Check the LabVIEW Version Compatibility Chart
  2. Check the LabVIEW and Microsoft Windows Compatibility
  3. Check PXI Platform Services Compatibility
  4. Check PXI Card Compatibility with PXIe Chassis
Click the broken run arrow on the code to see the broken references from the last chassis and other modifications that need to be made to the code. Often times, modifications must be done to the code are necessary whenever making a full migration of hardware.
Keep in mind the drivers that are being used in the project code; those will need to be installed during the migration (if they aren't already).
