Virtual memory allows Windows to use a portion of disk storage as an extension of physical memory (RAM). When memory resources become limited, Windows can move inactive memory pages from RAM to disk storage, making additional RAM available for active applications. In Windows, this storage area is commonly referred to as the paging file or swap file.
Virtual memory can help in some memory-related scenarios in LabVIEW. For example, when initializing very large arrays, LabVIEW may return a Memory is Full error. This behavior can occur when LabVIEW cannot locate a sufficiently large contiguous block of memory. Increasing the available virtual memory may allow Windows to provide additional paging space and enable the allocation to complete successfully. However, virtual memory is significantly slower than physical RAM and should not be considered a replacement for adequate system memory. Increasing virtual memory will not resolve memory leaks or inefficient memory usage within an application.
To modify virtual memory settings in Windows 10 or Windows 11:
- Open Settings.
- Navigate to System>>About.
- In the Related links section, select Advanced system settings.
- Select the Advanced tab of the System Properties window.
- Under Performance, select Settings.
- Select the Advanced tab of the Performance Options window.
- Under Virtual Memory, select Change.
- Disable the Automatically manage paging file size for all drives checkbox.
- Select the Custom size option.
- Configure the desired initial and maximum paging file sizes.
- Click the Set button, then click OK to close each window.
- Restart the computer for the changes to take effect.
