To access the sequence file version manually, navigate to
Edit»Sequence File Properties. You can view and modify the version number of your sequence file from here. For more information on the Sequence File Properties Dialog Box, see
TestStand 2019 Help: Sequence File Properties Dialog Box.
In TestStand 2.0.1, the PropertyObjectFile's
Version method is not available in the TestStand API. However,
RunState.SequenceFile.Data.Version is a hidden property that you can use to retrieve sequence file version. Because it is a hidden property, you will not be able to see it in the Expression Browser or the SequenceContext until you have enabled the
Show Hidden Properties option in TestStand. This can be done by selecting
Configure»Station Options, clicking the
Preferences tab, and enabling the
Show Hidden Properties option. This hidden property is available in TestStand 2.0.1, TestStand 3.0, and all later versions. See the attached sequence for an example of using this API function.
