Configure DIO Pins on Multifunction I/O Module
Updated Feb 19, 2018
  • PXI-6289
  • Multifunction I/O Device
I have a Multifunction I/O device and I would like to to configure the DIO pins.  How can I do this?
There are a few options for configuring your DIO pins:
Test Panels:
Test Panels provides you with the lowest possible and direct access to the actual signals being read or generated by a device.
LabVIEW:
LabVIEW will give you more flexibility and configuration options for use with your measurements.  As a starting point for this reference Connecting Digital Input Signals to a DAQ Device and Connecting Digital Output Signals to a DAQ Device
You can also use LabVIEW Shipping Examples as a starting point for your project.
