In order to successfully install the Teacher Edition with a silent install, you must manually specify the required feature states in the spec file as opposed to specifying the Installation Type. To silently install the Teacher Edition,
- Under the [Features] section of the spec file
- Add the line: EV3_EDU_Mode.EV3.EDU.MODE.100=Local
You may also download the spec file attached below.
