Note: The last version of the NI-DAQmx Base driver available for download is 15.0. Please check compatibility for Windows, Linux, and macOS for supported versions of this driver. Starting 2018, NI-DAQmx for Linux is included with the NI Linux Device Drivers. For more information, please read the End-of-Life Announcement for DAQmx Base Driver.To fix this error, make sure that the following 32-bit packages are installed on your 64-bit system before installing NI-DAQmx Base. They can be installed from the 64-bit installation disks, or from the online repositories for your Linux installation.
- compat-libstdc++.i686
- expat.i686
- glibc.i686
- glibc-devel.i686
- libdrm.i686
- libgcc.i686
- libselinux.i686
- libstdc++.i686
- libX11.i686
- libXau.i686
- libxcb.i686
- libXdamage.i686
- libXext.i686
- libXinerama.i686
- libXfixes.i686
- libXxf86vm.i686
- mesa-dri-drivers.i686
- mesa-libGL.i686
- nss-softokn-freebl.i686
- zlib.i686
Note: The *.i686 suffix denotes a 32-bit package, as opposed to *.x86_64 which denotes a 64-bit package. Make sure to install the 32-bit versions of these packages.
