It is not possible to directly convert a LabVIEW VI into a LabWindows/CVI program. However, you can call LabVIEW VIs in LabWindows/CVI. Since not all toolkits in LabVIEW have a direct LabWindows/CVI equivalent library, a common workaround is to follow the instructions below to call the LabVIEW VIs from LabWindows/CVI. The method for calling these VIs will depend on your version of LabVIEW.
LabVIEW 6.0 or greaterLabVIEW VIs can be built into a dynamic link library (DLL). Refer to the
LabVIEW Help for more information (
Fundamentals»Organizing and Managing a Project»How- To»Using Build Specifications»Building a Shared Library). This DLL can then be called easily from LabWindows/CVI (see
Calling a LabVIEW DLL from a LabWindows/CVI or Other C/C++ project ).
LabVIEW 5.1 and earlierYou cannot build DLLs, but VI Server functionality allows ActiveX clients to control the execution of VIs. Since LabWindows/CVI 5.0 offers ActiveX Automation Client functionality, you can control and interact with LabVIEW's VI Server in a LabWindows/CVI application and run VIs in that manner (see
Developer Zone Example: LabWindows/CVI Controlling LabVIEW).
