Deploying a LabVIEW Real-Time Startup Executable Without the LabVIEW Development Environment
Updated Jul 23, 2019
  • CompactRIO Chassis
  • LabVIEW Real-Time Module
  • LabVIEW FPGA Module
  • NI-RIO
  • NI CompactRIO
  • I have a built a LabVIEW real-time executable that I need to deploy to a real-time target, but I do not have access to the LabVIEW Development Environment. Is this possible?
  • I have the LabVIEW real-time code from my developer, but I don't have the Real-Time and FPGA module installed in my version of LabVIEW. How can I deploy the code without using the LabVIEW Development Environment?
If you have a LabVIEW executable file, but do not have the LabVIEW Development Environment nor the Real-Time and FPGA modules, you can still deploy your startup executable to PharLap, VxWorks, and Linux targets through one of the available solutions below.
  • Using identical hardware. It is possible to deploy the executable on a duplicate image via the Replication and Deployment (RAD) Utility. If you need to deploy to a Linux Real-Time target outside of the LabVIEW Development environment, this is the recommended method. Instructions for how to install and use RAD are included in the previous link.
  • If the executable has been compiled for the correct target. You can FTP the file onto your real-time controller:
    1. Place the executable in the c:\ni-rt\startup\ directory.
    2. Set the following two settings in the NI-RT.ini file or lvrt.conf file on the target. The NI-RT.ini file is located in the root directory of the target, at c:\ni-rt.ini for PharLap/VxWorks targets. For Linux targets, you will need to use the lvrt.conf file, which is located at etc/natinst/share/lvrt.conf.
RTTarget.ApplicationPath=c:\ni-rt\startup\startup.rtexe
RTTarget.LaunchAppAtBoot=True
where startup.rtexe is the name of your executable file.
While this method works, the recommended method for deploying a LabVIEW Real-Time startup executable is to do so through the LabVIEW Project .
The reason you have to modify the NI-RT.ini or lvrt.conf file settings is that when you deploy the executable to the real-time controller using the LabVIEW Project Explorer, LabVIEW sets the two flags automatically. Therefore, if you are transferring the start-up executable to the controller via FTP, then you need to set these two flags manually.
