このコンテンツは設定された言語で表示できません。
Running Shell Commands and Custom Applications in Linux Real-Time OS from LabVIEW
Updated Jun 1, 2023
  • myRIO-1950
  • myRIO-1900
  • cRIO-9067
  • cRIO-9066
  • cRIO-9038
  • cRIO-9065
  • NI Linux Real-Time
  • Linux
Programming Language
  • C
  • C++
I have an NI device that runs Linux Real-Time and I would like to send it Shell commands from LabVIEW or custom compiled C or C++, how can I do this?
This article will discuss how to do this with the System Exec VI in a Shell-like interface. If you are interested in an alternative method please see Using WebDAV to Transfer Files to Your Real-Time Target.
1. Set up a IDE of your choice
To target NI Linux Real-Time in C/C++, you need a cross-compiler and an integrated development environment (IDE). NI provides extensive documentation based on GNU C & C++ Compile Tools as well as Visual Studio Code. You can use this documentation to create your own toolchain, too. For more information, visit Getting Started with C/C++ Development for NI Linux Real-Time.
2. Write and compile your C or C++ program
Using the IDE of your choice, write your C or C++ program. Use the information found in Getting Started with C/C++ Development for NI Linux Real-Time to debug and cross-compile your program.
The following code block is an example written in C, which will be used as a reference:
#include <stdio.h>
int main(int argc, char *argv[])
                int sum, num1, num2 = 0;
                if(argc == 1)
printf("no arguments specified");
                else if(argc == 3){
                sscanf(argv[1], "%d", &num1);
                sscanf(argv[2], "%d", &num2);
                sum = num1+num2;
                printf("%d", sum);
                else
printf("incorrect number of  arguments specified");
                return 0;
Following up with this example, the C code file will be called main.c and the compiled file will be called test.
3. Copy the file over to the target
The easiest way to do this is to use a mapped-drive with WebDAV protocol on Windows 7 to home/lvuser directory on the LinuxRT target. For more information, see the KnowledgeBase article in 'Related Links' below, on using WebDAV to transfer files to your real-time target.
4. Set the file permission for read and execution
SSH into the target and set the appropriate permission to the test file by typing in chmod 777 (777 argument changes the permission of the file to read, write, and execute for all).
E.g.:
chmod 777 /home/lvuser/test
To SSH into the target, any terminal program (e.g. PuTTY) can be used. Use the regular target IP address and port number 22.
5. Access and run the file from LabVIEW
Write a simple LabVIEW application that concatenates the test file called and arguments into a Shell call string, and use the System Exec.vi to call the compiled C code. See below for an example.
There are two general ways to run custom C or C++ code on a LinuxRT device in a LabVIEW VI. The user can either compile the code into an executable and run it using the System Exec VI, or a shared library can be compiled and functions can be accessed with the Call Library Function Node.
