How Much Memory Can LabVIEW 32-bit or 64-bit Allocate?
Updated Jul 19, 2022
I am developing an application in LabVIEW on a Windows machine that requires large amounts of data to be stored in memory. However, after allocating a certain amount of memory, LabVIEW crashes. Is there a limit on the amount of memory that I can use in LabVIEW?
The amount of memory LabVIEW can utilize depends on the bitness of LabVIEW and operating system used.
LabVIEW (32-bit)
  • On a 64-bit Windows operating system, LabVIEW can access up to 4 GB of virtual memory without modification.
  • On a 32-bit Windows operating system, LabVIEW can access up to 2 GB of virtual memory by default. This can be extended to 3 GB by changing Windows' Boot Configuration Data store.
LabVIEW (64-bit)
  • LabVIEW can use up to 16 TB of virtual memory when using LabVIEW 2009 (64-bit) or later on Windows Vista (64-bit) or later.
  • In versions of LabVIEW previous to 8.5, LabVIEW can only use 2 GB of memory. However as of version 8.5, LabVIEW is large address aware and can assign addresses to more than 2 GB of virtual memory. Virtual memory is the memory available to the process that is running.
  • For more information on how LabVIEW uses memory in Windows, see the VI Memory Usage - LabVIEW 2018 Help .
