How Many GPIB-USB Controllers Can I Use at Once?
Updated May 20, 2022
  • GPIB-USB
  • GPIB-USB-B
  • GPIB-USB-HS
  • GPIB-USB-HS+
I need to use multiple GPIB Boards in one system. How many GPIB-USB-B and/or GPIB-USB-HS controllers can I use in a PC at the same time?
The NI-488.2 driver can currently support up to 100 GPIB controllers. This includes those connected by PCI, PXI, USB, and others.
In most systems, the maximum number of GPIB-USB controllers is limited by the power supply of the associated USB port. The maximum specified current draw of the GPIB-USB-B is 200 mA and 500 mA for the GPIB-USB-HS. Using a self-powered USB hub may enable the expansion of the number of USB controllers for any given system, as long as the system does not exceed 100 GPIB controllers.
Note: All GPIB controllers from NI act as System Controller by default. In any one GPIB system, there can only be one System Controller. You can change this setting through Measurement & Automation Explorer (MAX).
