Assuming we already have a stored procedure called storedprocedure() which is defined similarly to the following:
CREATE PROCEDURE dbo.storedprocedure
theVariable varchar(10) OUTPUT
AS
theVariable = 'return me'
RETURN
If a return value is needed from the database table, the SQL query input should be set to
{? = call storedprocedure()}
where the question mark declares a parameter to be defined by the parameter input.
Then, using the DB Tool Execute Query VI and DB Tools Get Parameter Value VI, the return value can be retrieved either by index or by name as shown below.
Note that DB Tool Execute Query VI creates a RecordSet reference, so you must use the DB Tools Free Objects VI to release the RecordSet reference value and retrieve the return value as shown above.
When using an Oracle database, you may also need to ensure that a RecordSet is defined and implemented in the Stored Procedure as shown below:
VARIABLE_RECORDSET OUT SYS_REFCURSOR
OPEN VARIABLE_RECORDSET FOR
SELECT VARIABLE_ID
FROM variable
WHERE variable_id = VARIABLE_ID_OUT;
