Yes. Depending on the version of MAX you have installed, there are two possible ways to do this.
MAX 4.7 and later:You can use the System Configuration API VIs which allows you to programmatically import and export your MAX configuration from LabVIEW. In LabVIEW, you can find
Export.vi and
Import.vi on the block diagram under
Measurement I/O»System Configuration. You can use these VIs to import configuration data from a file into MAX or export configuration data from MAX out to a file.
For example, to export your current MAX configuration to file, you would wire the session in input either with a System Configuration I/O control or with a string input of the hostname of your system, such as localhost. Then, you could wire the destination input with C:\MaxConfig.nce.
Note: This functionality is available for LabVIEW 8.5 and later.
MAX 4.1 through 4.6.2:You can use the MAX Configuration API. In LabVIEW, you can find the MAX Copy Configuration VI on the block diagram under
Measurement I/O » MAX Configuration. You can use this VI to import configuration data from a file into MAX, export configuration data from MAX out to a file, or copy configuration data directly from system to system.
For example, to export your current MAX configuration to file, you would wire the source input with system://localhost and the destination input with C:\MaxConfig.nce. It is also very imperative that examine capitalization and formatting in accordance with the help file as this VI is very strict when selecting inputs
Note: This functionality is available for LabVIEW 8.0 and later.
