Built-in Serial ports of cRIO or sbRIO cannot be directly accessed through FPGA. These ports are accessible only from the Real-Time section, where they show up as a standard VISA resource. It is recommended to use Serial VIs and functions to communicate with devices connected to those ports. Additional functions are also available in the VISA palette.
If your application requires serial communication to be implemented on FPGA, there are several ways to do it, however, additional hardware may be necessary:
Please note, that it may not be possible to connect C-Series modules to all sbRIOs. In case your sbRIO does not have C-Series module connectors, but it is equipped with RMC Connector, you may still connect C-Series modules via
CompactRIO Single-Board Controllers.
