TestStand Installer Error: customresource0009.dll Not Found
Updated Dec 6, 2017
  • TestStand
  • LabVIEW Base
  • LabVIEW Professional
Other
TestStand Deployment Utility
I am using TestStand Deployment Utility to build a TestStand installer. When I try to launch my TestStand installer, I am getting one of the following errors:
  • Fatal error, unable to load resource customresource0009.dll, installer error 1007.
  • Unable to load the file customresource0009.dll because of Windows error 127, the specified module could not be found.
Create a new build specification from scratch and rebuild the installer.
This issue has been linked to installer or registry corruption. In the event that rebuilding the installer does not correct the issue, a reinstallation of software may be required.
