Error -17329: Types Conflict in TestStand
Updated Nov 13, 2025
  • TestStand 2016
When working with TestStand sequence files and custom step types, you may encounter the following run-time error:
Error Code: -17329; Invalid type - conflicts with an existing type.
This error occurs when TestStand detects two versions of the same type with conflicting definitions. Common causes include:
  • Opening example sequences that introduce updated types.
  • Saving process models after loading examples.
  • Changing Allow Automatic Type Conflict Resolution settings in Configure » Station Options » File.
  • Loading sequence files that reference older type versions while newer versions are in memory.
  1. Check Station Settings
    • Verify the Allow Automatic Type Conflict Resolution setting under Configure » Station Options » File.
    • Recommended setting:
      • Only if a Type Palette File will not be Modified (default).
      • This allows TestStand to automatically resolve harmless conflicts without prompting.
    • Other options:
      • Only if a Type Palette File has the Higher Version
      • Never
        • Note Changing these settings after saving updated types can increase conflicts.
  2. Use the Type Conflict Dialog
    • If TestStand cannot resolve the conflict automatically, you will see the Type Conflict in File dialog. Options include:
      • Use Type from File – Load the type from the sequence file.
      • Use Type in Memory – Keep the type currently loaded.
      • Rename One of the Types – Safest option when changes are significant.
      • Cancel – Abort loading the file.
  3. Maintain Type Versions
    • Increment type versions whenever making intentional changes.
    • Do not disable prompts for type changes—warnings help prevent accidental propagation.
    • Coordinate changes with your team if using shared type palette files.
  4. Best Practices
    • Keep type palette files under source control.
    • Confirm changes before saving modified types.
    • Use the Modified flag as an indicator of edits.
    • Stick to default station settings for balanced automation and safety.
  • TestStand uses type definitions with version fields and modified flags. A conflict occurs when:
    • Two versions of the same type exist in memory or files.
    • Versions differ or modified flags are set.
    • Automatic resolution settings prevent silent resolution.
  • TestStand can resolve conflicts automatically if:
    • Type versions differ.
    • Neither type has the modified flag set.
  • Default behavior:
    • Automatically resolves conflicts unless a type palette file would be modified.
    • Prompts only when there’s a risk of unwanted type propagation.
