If you encounter Error -1074384895 with NI-XNET 2025 Q3 or earlier when creating a CAN session using Signal Out XY after performing a Signal XY read or write, and you're using a proprietary FIBEX database, the issue may be caused by COMPU-METHOD metadata in the CODING elements of the database.
