ATML Report Generation Fails with Exception in 'Generate Report'
Updated May 3, 2018
  • TestStand
Other
ATML Reports in TestStand
I am running a sequence in TestStand that generates an ATML report. I am getting one of the following errors.
-1; User-defined error code, although I have not defined this error. This error occurs at Get ATML Report Section Action, the function is Get_Atml_ReportSection_For_Body.
With on-the-fly reporting enabled:
An exception occurred inside the call to .NET member 'GenerateReport':
System.Runtime.InteropServices.COMException (0xFFFFBC6B): Index out of range.
at NationalInstruments.TestStand.Interop.API.ReportSections.get_Item(Object index)
at NIOTFReportGenerator.CollectionStepResult.UpdateExisting(IStepResult updatedStepResultI, Boolean usingConserveMemory, ReportFileStream& tempFileStream)
at NIOTFReportGenerator.ChildStepResults.ProcessNewStepResults(Hashtable& newThreadSeqCallResults, Boolean usingConserveMemory, ReportFileStream& tempFileStream, String[] reportSnippets, Int64 offsetAdjustment)
at NIOTFReportGenerator.OTFRptGenerator.GenerateReport(SequenceContext sequenceContext, String inputReportHeader, String inputReportFooter, ReportSection& mainSequenceReportSection, String& errorMessage, Double& errorCode, Boolean& errorOccurred)
Check whether any parameter names or step names are very long. If dynamically modifying them in a loop and appending to the end of the name each time, the names could become long enough to cause errors.
It is a known issue that when names of parameters or steps are longer than 512 characters, ATML report generates this exception. Behind the scenes, the name is copied at some point to a character array of size 512 during ATML report generation.
