Safe Mode is Accessible
This issue may be caused by your computer's BIOS. If it does not comply with the PCI BIOS Specification (Revision 2.1 as published in 1994), you may experience a system crash. In particular, calls into the BIOS32 Service Directory to detect the PCI BIOS 32-Bit Service must return correct values for both the base address and length of the service. Please check with your computer vendor to determine if they have an updated system BIOS available.
Safe Mode is not Accessible
This issue typically occurs due to an unstable disk image. If your computer's system was initialized with a disk image, it is possible that all the system files are not compatible with your computer's hardware. You most likely need to repair your system.
