Make My For Loop Run Faster
Updated Apr 4, 2023
  • LabVIEW Base
  • LabVIEW Professional
  • I need my for loop to run faster.
  • My for loop is running too slowly.
  • I want all of my processor cores to work on processing a for loop.
LabVIEW has a feature to allow a single for loop to be run on multiple processor cores, speeding execution.  To enable this, do the following:
  1. Right click the for loop, and select "Configure Iteration Parallelism."
  2. Select enable in the resulting menu.
In LabVIEW, separate functions are automatically run in parallel if possible.  However, loops are usually executed in order: the first cycle of the loop will execute, followed by the second.  This can be changed by enabling the feature in the solution, allowing for each computer core to run different loop cycles in parallel.  This reduces the time it takes for the entire for loop to finish.
