The following steps show how to
modify a subcircuit or a hierarchical block symbol:
- Select the subcircuit you want to modify by left-click on it
- Select Edit»Edit Symbol/Title Block to launch the symbol editor
- In the Symbol Editor make the changes you want such as re-arrange the pins, draw a new graphic or import a bitmap.
- Once you are a happy with the symbol you created, select File»Exit.
Note: Do not select
File»Save As and save the file in a different location, Multisim will not find it.
- You will be asked if you want to save the changes click the Yes button to exit the Symbol Editor.
load a block symbol to a component:
1. Select the component you want to modify.
2. Select
Tools»Component Wizard to create or modify the component.
3. Follow the steps until you get to
Step 3 of 8 window. Click on
Edit to launch the Symbol Editor.
4. Once in the
Symbol Editor you can make changes to the symbol or click
File»Open to load a symbol previously created from your computer.
5. Once you are happy with the symbol you created select
File»Exit.
Note: Do not select
6. Click
Next to continue the creation of the component.
