Dynamically Adjust Logic Level on FPGA R Series Board
Updated Sep 20, 2018
  • PXIe-7820
  • PXIe-7858
  • NI R Series Multifunction RIO
I know I can change digital logic levels (e.g. 1.2V, 3.3V) on my digital R series cards/boards from NI MAX. Are these digital logic levels on my R Series cards dynamically/programmatically adjustable while the application is running?
USB R Series:
Connector DIO Logic Family can be accessed programmatically via FPGA Target Property Node for USB R Series devices.
PXIe R Series:
FPGA PXIe R Series cards do not support programmatcally changing the Logic Family with the FPGA Property Nodes. A potential workaround is create a new build specification and compile a new bitfile for each logic family that you want to use during runtime. Logic families can be changed in the project explorer. Then, in the host VI, open FPGA references by bitfile and use the different bitfiles to run the card at different logic levels.
