Layout-only component
If you only need the component for schematic capture and layout, then you can simply create a Layout-only component in the Component Wizard by defining the symbol and footprint information. In this case, you will need the component’s datasheet to identify the pinout, select the footprint, and map the symbol pins to the footprint pins.
Simulatable component
This is a component that can be simulated in Multisim to understand and predict circuit behavior. To create a simulatable component using the Component Wizard you need the component’s datasheet and a SPICE model, which is a text-based description of a circuit component. The best place to look for SPICE models is the manufacturer’s website. The SPICE Simulation Models page contains a list of some of the most popular semiconductor manufacturers.
If you are not able to find a SPICE model to simulate an IC component you can look for the SPICE model of a similar or a cross-reference part (i.e. another manufacturer) or alternatively, create a SPICE macro model by using the equivalent circuit of the IC. Refer to
Creating a SPICE Model From a Macro Model Circuit Schematic in Multisim.
