The TestStand Sequence Editor and
LabVIEW, LabWindows/CVI, Visual Basic, C# and C++ Operator Interfaces now supports command line options to run sequences. Listed below are examples showing how to run a particular sequence in a sequence file, and how to run an execution entry point, such as
Test UUTs. For the examples below we assume that you want to run the sequence file with one of the operator interfaces listed above. If you want to run the sequence file with the TestStand Sequence Editor replace
testexec.exe" with
SeqEdit.exe".
Run MainSequence in the ASequenceFileToRun sequence file:
testexec.exe -run MainSequence c:\sequenceFiles\ASequenceFileToRun.seq
Run the ASequenceFileToRun sequence file with the Test UUs execution entry point:
testexec.exe -runEntryPoint "Test UUTs" c:\sequenceFiles\ASequenceFileToRun.seq
Load multiple sequence files:
testexec.exe c:\sequencefiles\ASequenceFileToOpen.seq c:\sequencefiles\AnotherSequenceFileToOpen.seq
To make a sequence file execute TestUUTs simply by double-clicking it (e.g., from Windows Explorer), perform the following steps:
- Create a shortcut for the sequence file; i.e., right-click on the sequence file and select Create Shortcut from the pop-up menu.
- Right-click on the newly created shortcut and select Properties from the pop-up menu.
- Select the Shortcut tab in the Properties window that appears.
- In the Target field enter:
- Click the Apply button and then click the OK button to close the Properties window.
For all the examples above, we assume that your operating system is configured to recognize relative paths to this executable. If you do not get good behavior from running testexec.exe from the command line, you may want to try an absolute path to your executable. Remember that if your paths have any spaces in them, you will be required to add "..." around your paths for the command line to interpret them correctly.
To see a list of all available commands in the Command Line for TestStand, type:
"C:\Program Files (x86)\National Instruments\TestStand 2017\Bin\SeqEdit" -?
You should see a dialog like below:
