Why Does my Test Sequence Fail When VI Front Panel is closed?
Updated Nov 29, 2017
  • TestStand 2013
I am calling a VI in my TestStand test sequence, and it seems to fail when the front panel of the VI is closed. How could I resolve this issue?
In order to resolve this, you can call the VI dynamically in TestStand. This should ensure that the test sequence passes even when the front panel of the LabVIEW VI is closed.
For more information on this can be found in the related links below.
