LabVIEW uses ASCII character formatting. Therefore, reading from another character set file will not work as expected in some cases. You can use the Configuration File VIs for Windows configuration settings files only in the ANSI format.
Sometimes LabVIEW will be able to read just one section of the file, and not all the keys if the file is not formatted correctly.
