This timeout-based error means that VIPM is having trouble connecting to the LabVIEW VI Server through a TCP/IP port. To facilitate the installation and uninstallation of software, it is crucial to ensure that the LabVIEW VI Server is accessible to VIPM requests.
Follow the steps below to verify and configure the VI Server connection settings in both LabVIEW and VI Package Manager.
In LabVIEW
- Open LabVIEW and click Tools » Options... to open the Options dialog box.
- Select VI Server from the Category section on the left.
- Enable the TCP/IP option in the Protocols section.
- Note the current port number (the default is 3363). Both LabVIEW and VI Package Manager must be configured to use the same port. If multiple versions of LabVIEW are installed, each may use a different port. The example below shows a correctly configured Protocol section:
- VIPM may reference LabVIEW by hostname or IP address, and the appropriate choice depends on the system’s network configuration.
In the Machine Access section, make sure one of the values below is listed under Machine access list. To add an address, make sure Allow access is selected, click Add and then and enter an address in the Machine name/address field. Test each option to determine whether it allows VIPM to successfully connect to LabVIEW:
• localhost
• 127.0.0.1
• * (asterisk)
• Your computer’s IP address
• Your computer’s name
Note: In most cases, using the default * is enough, but as this means "allow anyone to access me", and your IT might not like it. Also, depending on the system, it will complain if you use localhost, so this is why we suggest you to try these different settings.
- Click OK to apply the changes and close the Options dialog.
Note: You will get an Security Warning when you modify your Machine Access list, as shown below. That is just for your awareness. Click on Continue:
Warning 1 occurred at Security Warning When Modifying VI Server TCP/IP Access
Possible reason(s):
Modifying the machine access list or the user and group access list does not affect VI Server clients that are currently connected to this TCP/IP server.
To disconnect clients currently connected, disable TCP/IP access from the VI Server:Configuration page and click OK.
In VI Package Manager
- Open VI Package Manager and click Tools » Options to launch the Options dialog box.
- Click the LabVIEW tab.
- Confirm the Port number matches the previously configured LabVIEW VI Server port number. Click the Edit the LabVIEW connection settings button (pencil icon) to change the port number if needed.
- Click the Verify button.
Refer to the following dialog box for an example of a completed LabVIEW configuration:
VI Package Manager will then restart LabVIEW. When LabVIEW starts back up, the VI Package Manger will establish a connection, and you will be able to install packages.
Additional Troubleshooting Steps
If the above steps do not work, you can also try the following:
- Turn off any firewalls or antivirus software you have on your computer. If using Windows, you can do this by opening up the Control Panel and going to System and Security » Windows Defender Firewall » Allow an app or feature through Windows Defender Firewall. Verify that LabVIEW 20xx and VI Package Manager are allowed to communicate through the Windows Defender Firewall.
- Disconnect VPNs that are connected in your computer. Restart VIPM before trying again.
- Run the VI Package Manager in Administrator Mode by right-clicking the application shortcut found in the Start menu and selecting Run as Administrator
- Ensure that any updates made to the VI Package Manager have been completed and that VI Package Manager is up to date. Go to [External] VI Package Manager General Options for instructions on how to check for updates every time you launch VI Package Manager.
- If you are using Linux, you can attempt to manually copy the files from a Windows-based machine to your Linux machine. You can review the process mentioned here [External] VIPM could not connect to LabVIEW 2021 (64-bit) - Linux Opensuse Leap 15.2.
- You can also contact [External] JKI's support as another resource, as they are the author of this tool.
