How to Restore LabVIEW RT Target to Factory Default Configuration
Updated Apr 8, 2020
  • PXI Controller
  • myRIO-1950
  • myRIO-1900
  • CompactRIO Controller
  • USRP Software Defined Radio Stand-Alone Device
  • Controller for FlexRIO
  • I need to restore my CompactRIO (cRIO), sbRIO, PXI Real-Time controller, stand-alone USRP controller, or other real-time target to factory default. How do I format the disk and reinstall the software?
  • Can I reset my cRIO from NI Measurement and Automation Explorer (NI MAX) without having to install any software (LabVIEW, LabVIEW Real-Time, cRIO driver)?
Please see below a list of important considerations before restoring your RT target to factory default configuration:
  • You will lose all programs and configuration data on your controller when you format the disk. Make sure you have a backup copy of any files you may need from your controller and make a note of your IP configuration.  There is no need to backup any of the driver or run-time files as they will be reinstalled after the format.
  • Prior to NI MAX 5.0, network settings could not be preserved and you have to manually put the Real-Time target into Safe Mode. Refer to your device's documentation on how to do this.
  • In order for NI MAX to recognize your remote hardware, make sure that both the device and the Host PC are on the same subnet and that you have the minimum software required installed on your Host PC as well. Otherwise you may not be able to see the device, or have the option to reinstall the software/reset the device.
The following steps are for NI MAX 5.0 and newer:
  1. Open NI MAX and expand Remote Systems from the Configuration tree.
  2. Right-click on the device and select Format Disk.
  3. If a Log In window appears, select OK.
  4. Select Attempt to restart into safe mode to restart the controller in Safe Mode.
  5. Select Preserve the settings for all network adapters
  6. Phar Lap ETS targets have the additional option of selecting a file system. We recommend the Reliance file system. For more information on the Reliance File system read this article: Format Real-Time PC or Real-Time PXI Target to the Reliance File System
  7. Click Format to format the controller and Yes to restart the controller once it has been formatted.
  8. If you choose to not preserve the network settings, after the controller restarts navigate to the Network Settings tab in NI MAX and configure the network settings.
  9. Right-click on Software and select Add/Remove Software - the Software folder will not be visible in the configuration tree in NI MAX if the controller does not have a valid IP address.
  1. Some controllers install using Recommended Software Set's (RSS)'s. If your controller does not have an RSS option, proceed to Step 11.
RSS's simplify the install process by automatically selecting the required base software components. Select the RSS for the version of LabVIEW Real-Time you wish to install.
The RSS selection will select to install the base requirements for that Real-Time and driver version. Next, another window will open allowing the selection of other optional install components.
  1. If the controller does not have a RSS option then the specific software must be selected manually.
  1. Select Next. Review the software to be installed.
  2. Select Next to begin the install process.
  3. After the software is installed the controller will restart. If you manually put the controller into Safe Mode, return the setting/dip switch back to off to allow the controller to restart normally.
If you are unable to format the disk, ensure that the Real-Time target is in Safe Mode. Refer to the device's documentation on how to do this.
If you are receiving an error stating:
Error while reading a file from the local disk.
The file may be corrupt or not present. The disk space on the Real-Time target is full. The following link will address this issue: Error While Reading From the Local Disk When Formatting Real-Time Target
