Missing Methods For Memory Error When Using FPGA Host Memory Buffer
Updated Jan 11, 2019
  • sbRIO-9637
  • cRIO-9068
  • sbRIO-9651
  • sbRIO-9627
  • sbRIO-9607
  • LabVIEW 2017 FPGA Module
  • NI CompactRIO 17.0
I would like to take advantage of Host Memory Buffer functionality in LabVIEW FPGA, thus I created a Memory in the LabVIEW project under the FPGA target and set implementation to DRAM in General page of Memory Properties Dialog Box.
Then, in the LabVIEW FPGA VI block diagram, I placed Write (Memory Method) and then I run the VI to launch compilation process.
However, compilation failed immediately after Generating Intermediate Files step, returning the following Code Generation Error:
Missing Method(s) for DRAM-based memory
The following method(s) are missing for Memory: Write. All DRAM-based memory items require Write, Request Data and Retrieve Data methods.
As the error message explains, when using DRAM-based memory items, you need to place in your LabVIEW FPGA code all three memory methods supported for this interface: Write Data, Request Data, Retrieve Data. All methods needs to be placed inside a Single Cycle Timed Loop (SCTL).
Host Memory Buffer support was released in NI CompactRIO 17.0 with initial support on the cRIO-9068, sbRIO-9607, sbRIO-9627, sbRIO-9637, sbRIO-9651 (SOM). We plan to support more targets in future releases.
