LabVIEW Evaluation Version Limitations
Updated Oct 28, 2026
  • What limitations should I expect when using the LabVIEW Evaluation Version?
  • How long can I use a free trial of LabVIEW?
Evaluating LabVIEW allows you to use the LabVIEW Professional Development System with some limitations to the functionality. The specific limitations vary for each version of LabVIEW and can be found below:
LabVIEW 2012 to Current
  • You will have the ability to use all VIs included in the Professional Development System, but you will only have access to the block diagrams of the VIs included with the Base Development System.
  • Upon installation you will be able to use the fully functional software package for a period of 7 days.
  • At the end of the 7 day trial, you will be given the option to extend your evaluation. Read How to Extend the Evaluation Period of NI Software for more information.
  • You will have access to the Application Builder but it will have a watermark on the front panel of the built applications.
  • Application Builder cannot use any "Additional Exclusions."
LabVIEW 2009, 2010, and 2011
  • You may use this version for a maximum of 30 days after the first installation.
LabVIEW 8.5 and 8.6
LabVIEW 8.2
  • You cannot install the LabVIEW Simulation module.
  • You cannot install the System Identification toolkit.
LabVIEW 8.0
  • You will have a watermark on the front panel of applications built using the Evaluation Version.
LabVIEW 7.0
  • You may run any VI for a maximum of 5 minutes.
  • You may keep LabVIEW open for a maximum of 30 minutes before you must close and re-launch it.
