Este contenido no está disponible en su idioma de su preferencia.
El contenido se mostrará en otro idioma disponible. Su navegador puede proporcionar una funcionalidad para ayudarle a traducir el texto.
Why is a Red Outline Around my Block Diagram
Updated Aug 22, 2023
  • LabVIEW Base
  • LabVIEW Professional
My block diagram has a red outline. What does this mean and how can I remove it?
The red line signifies a breakpoint on your block diagram.  To remove the breakpoint, open the tools palette by selecting View»Tools Palette or holding Shift+right-click on the Block Diagram.  Then select Tools Palette»Breakpoint Tool and left-click on any empty space in your block diagram.  The red outline and corresponding breakpoint will disappear.
A breakpoint is one of the tools that you can use to debug your LabVIEW VI. Normally, you would use this tool on a wire to pause the execution of your VI at a particular point, but it is very easy to accidentally click the block diagram itself, instead of a wire.
If this happens, a red outline will appear around your block diagram, and this will effectively pause your VI before anything on your block diagram executes. This is helpful, if you want to step through your VI while debugging, but it can make your VI behave strangely when you try to run it normally.
